conversion joint part# ?
Discussion in 'The Garage' started by muddawg, Nov 24, 2006.
  1. muddawg
    muddawg Registered Member
    Oct 24, 2004
    39
    Susanville, CA.
    I just swapped out the stock 10bolt rear for a 14bsf axle in my 95 k1500. Can anyone help with a part# for the converion u-joint?
  2. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    if a 14bff has the same yoke as the 14bsf then its a #447 napa u joint, hope that helps..if not...sorry im stupid!
  3. muddawg
    Oct 24, 2004
    39
    Susanville, CA.
    I'm not sure if they are the same? Guess that means i'm stupid too!
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    14ff and 14sf both have 1350 ujoints.
  5. muddawg
    Oct 24, 2004
    39
    Susanville, CA.
    well, i just picked up the napa #447 joint and it did not fit. The larger caps fit fine in the rear yoke but the smaller ones were too big for the driveline yoke and have inside snap rings and my stock driveline has the outside span rings. The smaller caps on the 447 joint have a diameter of 1.125" and my stock driveline takes a 1.063 diameter cap.Any ideas?
  6. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Take the old u-joint in with the one you bought and tell them this side fit but this side needs to fit this. It's not Pep Boys, it's NAPA, they will figure it out.:D
  7. 83 oneton
    83 oneton Registered Member
    Feb 11, 2006
    77
    clackamas oR
    you need drive line work!
