Conversion of 72 truck doors to blazer doors?
Discussion in 'The Garage' started by mudduck74, May 1, 2006.
  1. mudduck74
    mudduck74 Registered Member
    Mar 2, 2006
    9
    Michigan
    I found a local dealer who has brand new doors for a 1972 pickup truck. I need to know if they can be converted to doors for my 72 K5. It looks like all I would have to do is cut the toprail about 3-4" off of its front angle and remove the rear window rail. But before I decide to purchase these doors I'd like a few opinions concerning this procedure. Any help would be gratly appreciated. Also can anyone point me in the direction of some custom sot top manufacturers. Thanks.
  2. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    Would have replied earlier but it took me a while to find it. Do a search in the 69-72 section under "turning a truck door into a blazer door?" This will tell you everything you need to know. You should have posted this in the 69-72 area.
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    yes you cut the tops off and you need the brace plates and caps from k5 doors
    the right way is to drill out the spot welds that hold the frame in and pull it out of the shell, but cutting them off works too
