Conversion question
Discussion in '1982-Present GM Diesel' started by jeffro, Sep 5, 2002.
  1. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    I want to stick a 6.2 in my 72. Will the poli tank I bought from Chevy Duty work or will the fuel eat the plastic. Will 3/8 gas line work or will the diesel cause it to deteriorate?
    Thanks in advance.
    Jeffro
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The fuel tanks and fuel lines should work just fine. Completely remove the tank and clean it out really well. That's what I have done. I removed the tank, dumped out all the gasoline, poured in some diesel fuel, sloshed it around, and repeated that process a couple of times.
    Do you have a donor truck to get all the accessories from, such as radiator, alternator, ps pump, etc? Also, do you have power brakes on the 72? If so, you may want to try and convert to hydroboost. I've still got a vacuum booster on my '81, but the vacuum pump on the 6.2L barely keeps up with it. You've got to wait for the system to build vacuum after starting the engine.
    Casey
  3. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    I have a complete 82 3/4 ton truck. I plan to use as much as I need. What about glow plugs. Are there better controllers to use besides the 82 model? I need to repair the glow plug system.
  4. arveetek
    Mar 1, 2002
    722
    The 85 and up glow controller is better and cheaper than the old style. Or, just use a momentary push button to activate them.
    Casey
