conversion u-joint problem
Discussion in 'The Garage' started by muddybuddy, Mar 26, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i went from 10b's front and rear, to 60/14b 1350's. the conversion u-joint i have for the rear works fine and fits perfectly. i tried to do my front, and the conversion ujoint cap is too big. and im using the correct one (s44-1350) what gives? are front/rear joints different?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, front and rears are different
  3. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    10 bolt and 44 and 60 front all use the same joint on the input of the axle. only need to change rear joint at axle end.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so then what u-joint do i need for the front? i dont think the chevy 60s came stock with 1350, i think only 1310.
  5. sweetk30
    Nov 1, 2004
    25,539
    538
    oh you didnt say that. sorry cant help you on this then. :doah:
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    You just need to get a stock 10b or stock 60 1310 u-joint
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Unless you had a new driveshaft made then I dont know why you are using a conversion joint. All Chevy front ends are 1310...
  8. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    ahh thats what i told u
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well i upgraded to a 1350 yoke, so i guess im kinda screwed since there is no conversion for it?
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    You can get a 1350 yoke for your front driveline, but thats more work.
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Should be the same U-joint for the front as the rear if you have a 1350 yoke on your D60. The front U-joint is a 1330 factory IIRC.
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well i got the nepco 2-1153 joint, and the head of the caps are too big to get into the driveshaft
  13. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    You'll need a 3-3140 to convert from your 1310 driveshaft to your 1350 D60 yoke.
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks for the part number, ill go get one!
