conversion U joint ?
Discussion in 'The Garage' started by 74757685k5, Jun 28, 2006.
  1. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    I put a 10bolt rear in my 78 short bed it looks like 10 bolt yoke is bigger.
    What is the part number for this?
    Sorry I cant search anymore I've been off line for a few months.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Jesse at High Angle Driveline can fix you up.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    You need a Spicer 1310 to Saginaw 44 Joint.
    Neapco PN 3-3130
  4. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Napa # 447 (Neapco 2-1153) is a Saginaw 44 - 1350 combo joint is used when going from a 10 bolt to a 14 bolt.
    Napa # 348 (Neapco 3-3140) is a 1310 - 1350 combo joint is used when going from a 12 bolt to a 14 bolt.
    Not sure what you have but this should cover it...
    EDIT: Sorry, I reread the first post, Ill find the correct number...
    EDIT AGAIN: Nevermind... thanks 83'
  5. 74757685k5
    Nov 13, 2004
    258
    montana
    thank you!
    I wrote them all down for the future.
