Conversion u-joint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cocky, Mar 25, 2000.
  1. cocky
    cocky Registered Member
    Feb 21, 2000
    88
    Northern Colorado
    A few posts down there is a post titled 14 bolt or 12 bolt. on one of the replies a guy said that he put a 14 bolt under his k5 and made a conversion u-joint so the driveline would bolt up. I asked him to explain but he hasn't replied. may he hasn't been on line since. any way does any body know anything about a conversion ujoint?
    Richard
    1970 k5 Blazer
    Don't stand in front of a train naked
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I have a U-joint that is commonly refered to as a "Trick Ujoint" One the driveshaft side, its 1310, on the S/F 14blt side its 1350. I hope this helps.
    COrey
    88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  3. Here is the one I used from NAPA: #447 and under the UPC code it says NUJ447. I think it was 24 bucks
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  4. cocky
    Feb 21, 2000
    88
    Northern Colorado
    Corey, did you make that or buy it. If you bought it, where? If you made it how.
    BigBurb, what axles are you running?
    Richard
    1970 k5 Blazer
  5. Boggin' Blazer
    Boggin' Blazer 1/2 ton status
    139
    Sunny State of Florida
    Burb has a 14ff in the rear.
    I believe Corey bought the s/f 14 bolt. they were available in light duty 3/4 ton chevy trucks. I think somewhere around 88 and up. Any one can correct me if I am wrong.
    David
    [​IMG]Drive it like you<font color=red>Stole</font color=red>it!!![​IMG]
  6. 14 Bolt FF in the rear and 10 bolt 3/4 ton in front
  7. cocky
    Feb 21, 2000
    88
    Northern Colorado
    Burb, did the u-joint you bought fit w/o any modification for both your drive shaft and the 14 ff? Will this u-joint work in my 70 k5 and a 14 bolt?
    Richard
    1970 k5 Blazer
