conversion u-joint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tom, Jan 6, 2001.
  1. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    My blazer needs a repalcement for the u-joint at the rear differential, but I can't find the part.
    This is a conversion type joint. One set of trunion caps is 1.125" dia. and the other set is 1.187"dia (on the same u-joint). The distance across trunions is 3.625 with the caps in place.
    The Blazer is a '91, SM465/NP241 with a 10 bolt rear axle.
    Any suggestions on how I identify this part and where to buy one? I live in southern california.
    Thanks, Tom
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    hey,,check out a local auto parts store... i have bought them from napa,,summit may also have them
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    Try to find a parts store where the guys know how to use a book. More than likely it won't be an app. in the computer for a specialty u-joint. I used to work for NAPA so I'm sorta partial to them. But the book we used to use had a special section for conversion u-joints. If it is a direct replacement then ther shouldn't be a problem getting one. If the axle, or d-shaft is diff. then if you know the 2 applications they can look the 2 part#'s up and use the chart to get a good # for the u-joint you need. Hope this helps-Russell
  4. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    Thanks Russsel; Took your advice and drove to the NAPA store. The guy knew how to use the book and had the correct U-joint on the shelf. If anybody else has this combo, (think it is a 1350 type on the driveshaft and a 10 bolt diff yoke), the NAPA part number is NUJ.447. By the way, Auto Zone, Kragen, Pep Boys - none of them could identify the right part.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sadly, most parts stores these days are useless for anything beyond stock part applications. Try finding leaf spring center bolts. NAPA's the only place I found that carries them. The counter help at Pep Boys and Auto Zone looked at me like I had asked them how to build my own space ship. [​IMG]
  6. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Tom, if you haven't found one yet call Tom Woods: 1-877-4XSHAFT or www.4xshaft.com. He is a great guy and has them in stock.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  7. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    try this, NEAPCO is the company, the part numbers are, 2-3011 or 2-3011BF, go with the BF that stands for brute force. Its the performance U-joint. make sure this part number is correct before ordering it. I had a bud of mine who works at NAPA look up the part number.......js
