conversion ujoint problem
Discussion in 'The Garage' started by chulisohombre, Feb 16, 2004.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i used a conversion joint in my rear shaft and it is loose.a 3/4 ton full float 14 bolt uses a 1350 joint isnt it?the joint i used was a neapco #3-3140.is this the correct joint.when i looked in the book it came up with that number.it is a 1310 1350 conversion.the caps fit the right way but the trunion is about 1/8 of an inch too short on the 1350 side so the end caps can slide side to side and never seat on the center of the trunion.
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I think I have seen Jesse from High Angle post that it is very common for those yokes to spread. Otherwise you have a 1410 yoke - the only difference is the width of the joint - caps are the same diameter as a 1350.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is the correct joint. If it's loose in the yoke you either have a problem with the hardware or the yokes need to be replaced.
  4. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    did they ever put 1410 yolks on 3/4 ton rears?if so i think that is what i have.it is just a 1/16 of an inch wider than the 1350 joint i had in there.do they make a 1310/1410 conversion joint?or do i have to change the driveshaft yoke?
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They do not make any conversion joint to go to or from 1410 as far as I know.
    No stock truck from our era ever had 1410 joints.
  6. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    so somebody had to put in that yolk on my 14 bolt then?i will have to take a measurement and see what the width is to make sure what size joint it is.also will have to modify my driveshaft to take the 1410 yolk on that side.
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]I used a neapco 2-1153 with my 3/414BFF 1350 and stock 85' shaft. I see your truck is a first gen so my guess is that is why 2-1153 number didn't come up. /forums/images/graemlins/dunno.gif
  8. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
  9. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i guess my yolk on my 14 bolt is junk.there was not that much space in between the sides of the yolk.back to the junkyard for anether one.either that or the joint i got was off a little on size.thanx for the visual.
  10. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    rjfguitar i think that 10 bolts use a 1330 joint in the shaft instead of the 1310 in my 72 with 12 bolt.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    10 bolts use a Saginaw S44 joint.
    That is a Saginaw S44 to 1350 joint. He says he has Spicer 1310.
    A Saginaw S44 is a bigger joint than a 1310, significantly.
