conversion ujoint
Discussion in 'The Garage' started by chevylvr, Jun 15, 2004.
  1. chevylvr
    chevylvr Registered Member
    Jun 14, 2004
    6
    smithfeild,nc
    just swapped in a 14bff from a 77 sub into a 86 silv and was told i could get a conversion ujoint and was wondering if any one knew a part #
  2. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    napa #447 for a regular, the extra strength one is a different # ask them to cross it over. but this will get you in the ball park. lol
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    for some reason 348 rings a bell. might want to do a search also, i know this info is out there somewhere
  5. Saxwonder84
    Saxwonder84 1/2 ton status
    Jun 27, 2002
    117
    Rockwall, Texas
    Was it a total bolt on swap. I'm set to purchase an axle this week and I'm curious if it is going to be a direct bolt on.
    Jacob Byrd
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    348 is for older trucks with external locking clips (spicer 1310) which is part number 3-3140
    86 1/2 ton will use internal clips (saginaw s44) and thus uses 2-1153 or 447 in precision, take your pick.
  7. chevylvr
    Jun 14, 2004
    6
    smithfeild,nc
    pretty much except for e-brake lines need ubolts and plates
    being the axle is larger diameter /forums/images/graemlins/shame.gif
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Is there a heavy duty version for the 1310-1350? If so any #'s?
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No, it is not available any other way. Greasable through cross is it, and that is the only number available. 3-3140.
  10. chevylvr
    Jun 14, 2004
    6
    smithfeild,nc
    this 2-1153 is for a half ton shaft with inner clips that bolts to a 3/4 ton yoke and is not as wide across correct
    and thanks for the info /forums/images/graemlins/peace.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    2-1153 is for internal clips to spicer 1350. The spicer 1350 is wider, you're correct.
    No problem, any u joint questions and I'll attempt to answer, I've got a catalog. /forums/images/graemlins/thumb.gif
  12. chevylvr
    Jun 14, 2004
    6
    smithfeild,nc
    so this is the one I need to make this swap the 2-1153 is wider on one side than the other? the parts stores around here are not very up to date the last time I swapted in a 12 bolt for a 10 I didnt have this problem /forums/images/graemlins/dunno.gif
  13. chevylvr
    Jun 14, 2004
    6
    smithfeild,nc
    noticed you run 15 inch rims on your 84 do you have any probls going to install d44 in the morning and look to order rims soon <font color="white"> </font> /forums/images/graemlins/truck.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I run 15" wheels on my 84 with no problems. Front is a Dana 60 with 4 hours of grinding on each side to clear the wheels and tires. Rear is a 14 ff with discs and no grinding, clears just fine.
    Yes 2-1153 is wider one way than the other but only slightly.
  15. chevylvr
    Jun 14, 2004
    6
    smithfeild,nc
    thanks for the help /forums/images/graemlins/peace.gif
  16. chevylvr
    Jun 14, 2004
    6
    smithfeild,nc
    also the front if you are doing that required swapping the calipers /forums/images/graemlins/peace.gif /forums/images/graemlins/truck.gif
  17. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    I go to napa's website and type in 2-1153 and 447 and nothing comes up except for some snap ring pliers, and some springs. Will I have to go to the store to find one?
    Nick
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not sure why. They should have no problems getting the joints, they're fairly common.
    I could have a half dozen by tomorrow if I needed.
