convert 6 lug or rebuild 8 lug..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Nov 14, 2000.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    should i swap my 6 lug d44 from my 74, or rebuild annd swap in an 8 lug from a 3/4 ton? the 6 lug has the the tie rod on top of the knuckles, the 3/4 doesnt. and if i did convert the 6 lug, would it be the same strength as the 3/4 ton axle?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Don't bother swapping out the axle. Just tear your 6-lugger down to the spindle (keeping the axle on the truck) and swap in the 8-lug parts from the spindle out. Presto, bigger brakes and 8 lugs!.
    The only advantage to swpaping out the axlehousing entirely is if the gears in yours are bad, or if the ratio is lower in the 3/4, etc.
    Have fun.
    -- Mike
