Convert from manual to auto?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Quetzal_SJ, Nov 6, 2001.
  1. Quetzal_SJ
    Quetzal_SJ 1/2 ton status
    Feb 20, 2001
    123
    San Jose,Ca USA (BAY AREA)
    Just been thinking and would like to know if anyone has done this? What is involed,cost,difficult?
    Thanks Lico
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    IMO it is easer to convert from man. to auto than the other way around. There might even be some people willing to do swap parts w/ you (including me if you live in SoCal) [​IMG]
    You would need a trans, xfer case w/ adapter, shift column, driveshafts lengthend/shortened.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. Quetzal_SJ
    Feb 20, 2001
    123
    Would the crossmember have to be changed also? Also do you need to swap transfercases?
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Yes, you need to change transfer cases. Manual trans xfer case uses a 10 spline input and a th350 uses a 27 spline. You could just swap the shafts but you have to take the whole thing apart to do it.
    I don't think you have to swap the crossmember just move it back.
  5. Quetzal_SJ
    Feb 20, 2001
    123
    Guess you need to swap humps or patch and cut holes.So Triaged what kind of tranny do you have and what is th condition of you trans and transfer case? Also did you buy longer drive shafts for you lift? Does your colum have tilt?
