Convert my 10bolt to a 8 lug
Discussion in 'The Garage' started by trev1981, Feb 9, 2007.
  1. trev1981
    trev1981 Registered Member
    Dec 21, 2006
    72
    Manteca, CA
    How do i change my 10bolt to an 8 lug or should i just pull one out of a junkyard?
    I'm looking for a 14 bolt for the rear.
    Should I just pull the front off the same truck?
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    You can switch axles; if you get them both from the same truck you get matching gear ratios (presumably), which could get you 4.10:1's cheaper/easier than regearing if you now have, say, 3.73:1's. This was my sitch.
    Or you can swap the rotors, hubs and all the brake hardware and voila, have 8-lug. You can also steal parts from a D44, as they're the same from the spindles out, and if you get the right D44, might have flat-tops for crossover.
    -- A
  3. trev1981
    Dec 21, 2006
    72
    Manteca, CA
    ya i might just grab both off the same truck, I could use some 4.10s. I have 3.08s i think.
    I'm doing 1100rpms at 55mph on OD with 33s
  4. goldwing2000
    goldwing2000 Guest
    You can put all new 8-lug parts on for about $250. Part numbers and sources here:
    http://coloradok5.com/forums/showthread.php?t=175604
    Alternately, you can use used parts but I've never found any in good condition around here.
    If you can find a set on the same truck with a good ratio, then you're golden.
