convert serpentine belt alternator to single groove style ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ColAdo82K5, Oct 16, 2001.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey all,
    I've got an alternator from a friends engine swap. It's a brand new '86 small block camaro version. I want to use it on my truck because it is an 94 amp version compared to my alternator of unknown origin(maybe 63 amps). However, it has a serpentine pulley on it. I already took that pulley off and was wondering if my single pulley would go on and line up with the rest of the pulleys. I know It will mount up the exact same way using my exsisting brackets. thanks.
    Blake
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Should work fine, just keep the pulleys and spacers together.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    you might want to change to the serpentine style mine(88)has a seperate serpentine just for the alt the rest are seperate it doesnt squeal like the others.
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.11
  4. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    My '87 (motor) has the same goofy set up. Brother's '88 T/A is full serpentine, as well as our '89 'Burban.
    Pete
  5. ColAdo82K5
    Feb 18, 2000
    789
    MO
    The camrao has the goofy one sepentine belt setup also. I'd rather not use that pulley set up. I tried to put on a single groove pulley and the big threaded stud that the pulley goes on seems a hair short that it should be. the serp spacer is off. The single groove fan and pulley seem normal but the nut barely has enough threads to go all the way on, I don't see this as an issue exact for there's no room for that locking washer. What do you guys think ? try it with out the washer and just tighten the nut down a little extra or what ?
    Blake
