Convert Th350 To SM465
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by josephn, Apr 13, 2001.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    What is involved in this.
    And would a sm465 hold up better than the th350 under a 454?
    1982 6.2L Diesel K5 Blazer, TH700, 31 inch tires.
    Fire ALWAYS makes it better.
  2. dyeager535
    26,980
    Yours would be pretty easy, except again if the bell crank (z-bar) mounting point on the frame was not drilled..
    Get the tranny hump out of a donor truck, since yours should be bolted in. You'll need the adapter for a 465/208 combo, and maybe the front driveshaft, or at least have it shortened. Other idea is if you can find a complete donor truck, use a 465/205 K5 combo, and the driveshafts out of it, which should fit without mods, except you'd need adapter u-joints. Pedals etc bolt right up. 465 will hold up better than a well built 350 for longer.
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A><P ID="edit"><FONT SIZE=-1>Edited by dyeager535 on 04/13/01 12:13 PM (server time).</FONT></P>
  3. josephn
    Nov 3, 2000
    138
    Utah
    There are 3 donors that I am looking at right now a 465/208, 465/205, and Th400/205.
    I would realy like a manual setup.
    Doesn't the 465 have a lower 1st gear than the th400 and th350?
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The SM465 has a 1st ratio of 6.55:1
    I forget exactly what the 350 and 400 1st gear ratio are, but it is about 3:1 or so.
    I would HIGHLY recommend the 465/205 combo. You will never break it, period. Plus, having 4-lo on the 205 and lo on your 465 means you have a good crawl ratio from the start.
    The TH400/205 would be the better combo if you don't really like having a clutch. It's a preference thing.
    BTW, the swap itself is oretty easy, just time consuming. And, my z-bar holes were already drilled in the frame - I think they are all drilled, even the auto frames (my frame was OE with a 350/203.)
    -- Mike
  5. dyeager535
    26,980
    The later frames were not all drilled for the mount..my '81 was not. Maybe you will get lucky and they are there, Need to compare yours to a donor truck to see. If not, no fun trying to drill I bet.
    Dorian
  6. josephn
    Nov 3, 2000
    138
    Utah
    Thanks I think I will get the SM465/Np205 Combo.
    Now just have to descide where I am going to get my 454.
