convert to intermittent wipers
Discussion in 'The Garage' started by mdm365, Feb 24, 2004.
  1. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    We had rain here in vegas the last few days and I am tired of switching them off and on.(not enough rain comming down to keep them on)My question is can I switch them over to the intermittent style by using a switch for intermittent system?They do make a switch for 78-83 with intermittent wipers mine is a 77. thanks mike /forums/images/graemlins/thumb.gif
  2. dyeager535
    26,978
    The '81-up style (or it could be a different year break, not sure) won't fit in the older gauge "bezel". You've got to hack it up to make it fit, and it looks bad.
    I think there were delay wiper systems for your vintage, but if there are, I've never personally seen one.
  3. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    Check out Chevyduty, Brothers, LMC, or JC Whitney. I know that they have some.
  4. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I don't care what it looks like, my dash is so cut up now anyways. Is it just the switch? Do you have to hack the wireing also? And how many speeds does it have?
  5. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I put a set of intermittents into my '77. It was not too difficult. The new switch will fit if you carefully grind/file the metal behind the bezel. The knob sits out far enough that the bezel works just fine. The most difficult part is the wiring. The newer style runs the pink wire through the washer motor that is used in the newer water bottles. If you grab the schematics from the '77 and from an '83 you will see what needs to change. I did mine a while back but still may have my notes on the color codes if you need them.
    Mike
  6. dyeager535
    26,978
    On the later ('81+ at least) setups you simply pull the gauge bezel off, disconnect the controls, hook up the "delay" module to the now empty connector, then hook up the new delay control piece to the other end of the module. That's it.
    "infinitely adjustable" is how I would describe the delay wipers. Just like most other vehicles with delay, you turn the knob one way to make them swipe more often, the other way to slow down the operation.
  7. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I was able to do the same with my '79. Plug 'n Play /forums/images/graemlins/cool.gif
    James
  8. mdm365
    Jul 2, 2001
    536
    mineral wells wv
    /forums/images/graemlins/thumb.gifThanks for the info now all I have to do is find the parts. Thanks mike
  9. mdm365
    Jul 2, 2001
    536
    mineral wells wv
    Mike
    [/ QUOTE ] prjt-blazer. If you can find the color codes that will be a great help thanks mike /forums/images/graemlins/waytogo.gif mdm365@cox.net
  10. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    It may take me a day or two to find it in my paper work. I used the newer style motor and washer bottle on this as the newer bottle is a lot more useful and I did not like the washers hooked to the wiper motor.
    FWIIW, I have seen factory intermittent trucks in JYs once in a while. No idea if they work though and replacement parts could be a problem if you are thinking about that route.
    Mike
