converted diesel to gas, tranny questions
Discussion in 'The Garage' started by scrapper69, Apr 18, 2005.
  1. scrapper69
    scrapper69 Newbie
    Jan 12, 2005
    3
    Bucyrus, Missouri
    I took a 6.2 out of an '87 Blazer, and dumped in a 350 crate motor. I have done this before, but never retained the original tranny. I have the original tranny (700r4). I have read elsewhere and have heard that when doing this the valvebody, and the torque converter need to be changed back to a gas style. I was told because the diesel has a different stall to the converter and the valve body doesnt run as much pressure as the gas valve body. It runs fine, but it doesn't hook and haul ass like my other with a TH-350. It seems to be hesitant upon initial stomping of the gas. It will not spin the tires in dirt, yet my other with 33's and the TH-350 will spin all day. I have put the gas TV cable in, and its adjusted right, I'm left with the tranny guts itself. Also did this come with a lockup converter, or was that just the gas ones. I'm a SM-465 stud, and I know nothing to little about auto's. Like I said its in an "87 and its all original equipment. For those that might reply, the tranny is new. Not rebuilt, but new from Goodwrench. Any thoughts,,,???????????
  2. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Yup, you got it. Swap out the torque convertor and valve body.
  3. 79chevyk10
    Dec 14, 2003
    612
    Central Coast
    btw, a goodwrench tranny is rebuilt, not new. Even the sticker on the bell housing says, remanufactured by goodwrench, although does have alot of new parts inside.
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the valve body should not need to be changed but the govenor should be changed
  5. scrapper69
    scrapper69 Newbie
    Jan 12, 2005
    3
    Bucyrus, Missouri
    Thats what I figured, just wanted to get a few different opinions,,thanx
