converted to serpentine setup on a BBC and now have a few issues
Discussion in 'The Garage' started by Leadfoot, Nov 2, 2005.
  1. Leadfoot
    Nov 28, 2000
    Western Massachusetts
    1.) My alternator does not charge.
    I bought the plug from Painless wiring that adapts from the new style alternator to the old style harness. I have one thick gauge red wire going to the terminal and plug (12 v battery source) and one thinner gauge white wire (what does that go to and is there a test to see if it works). The ignition works fine and the truck runs, but it does not charge. Alternator is a new AC Delco unit (I'm going to have it tested this weekend).
    2.) My fan shroud does not work anymore. I looked at a newer (91) truck and the radiator/fan shroud is different and don't THINK it will fit. I could go electric $$$ but was hoping to avoid that. Any suggestions?
    Also, anyone have any old BBC valve covers they want to part with cheap?
    I want to cut up a set for valve adjustments, so the cheaper/older the better.
