Converter Bolts
Discussion in 'The Garage' started by SUPER'BURB, Nov 21, 2005.
  1. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    Do you guys run Lock Tight on your torque converter bolts? And if so what color and what torque do you put them at?
  2. keifer
    keifer Registered Member
    Nov 1, 2005
    16
    MD-Phoenix someday
    yes I run red loc-tite, cant remember the torque, have it written at home
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I use blue and torque them to "freakin tight". Red may require heat to remove, and I've never had a problem with blue.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    On bolts of any size (i.e. not a 10-32) I've never had trouble removing one with Red Lock-tite in the threads. I'd rather heat the bolt to remove them & risk destroying them than have those particular bolts come loose.
  5. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    I'll bet you that's because the person before did not clean the threads before applying the stuff. I cleaned the threads on my flexplate bolts and put the stuff on....my impact wouldn't remove them without heat. Try removing a DaimlerChrysler diff from a semi when each bolt has green on it.
  6. keifer
    Nov 1, 2005
    16
    MD-Phoenix someday
    I use new arp convertor bolts with red and can remove them with a 1/2 breaker bar
  7. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Alright....clean the threads, put so much red on there you can't see the threads and put 'em in... :rolleyes:
  8. keifer
    Nov 1, 2005
    16
    MD-Phoenix someday
    lmao,,,, how about myself and everyone else that uses red, put your next convertor in for ya?
  9. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Yeah...I'd trust you with that. :rolleyes: You'd probably put red loc-tite on the inspection cover bolts, too.
  10. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    That would be me, and I do use something like brake cleaner on both threads. FWIW, no matter how strong the impact I've seen cases where you need to use a breaker bar first. Lock-tite or no Lock-tite. Must be something to do with constant torque vs. impact, I don't know why.
    Which Green? There are at least two. One is pretty weak and is or can be used in already assembled fasteners to wick into the assembly.
    The other is stronger than Red. One use I know of for this stronger Green is to hold valve guide liners in iron cylinder heads. If it was that Green I'm surprised you got it apart w/o breaking things.
  11. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    Thanks for the answers guys, I will let you all fight about the color but I'm gonna go with tighter is better :D (and if you like blue don't take that personaly ;) ).
