Convertible Pick-up?
Discussion in 'The Garage' started by FOR MUD, Jun 21, 2006.
  1. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,804
    388
    Clayton Del
    I'm thinking about cutting the top off my 81 pick-up . I've got the windshield frame cutting and grafting part down and the doors are no big thing . But the back of the cab I'm not to sure about . I'm going to cut it flush with the bed and theres going to be a gap in the cab , should I weld in sheet metal or use fiberglass? When I did a search on this I saw alot of problems with flex on C-5s , is this going to be a problem on a pick-up? Do you know anyone who has done this kind of mod? I 'm planning on running a 10 point cage , should I tie it to frame with no roof?At least the welding should be alot easier with on roof!!!
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you need to leave the gap, the bed and the cab move seperately. ive seen my bed stick out 2" past the cab before.
  3. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    I dont know much, but i agree with above, iv seen some body flex on the pickups as well, leave the gap.. what about some loose carpet to cover the gap? done up so it has a bubble in it so it will allow flex?
  4. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    moutn some dimond plat toe the cab and let stick out so u dont see the gap but dont attach it to the bed
  5. FOR MUD
    Apr 6, 2006
    2,804
    388
    Clayton Del
    I'm talking about the gap thats going to be in the back wall of the cab , not the gap between the cab and bed . It looks like 1"-1 1/2" . I was wondering if I should weld it up or use fiberglass , just I don't know how much if any the cab is going to flex with no roof, and how much this would help.
  6. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    Weld It !
    I would recomend welding it...I'm not possitive, but that area could be designed in at the factory to help eliminate flex in the back wall of the cab, so if you just 'glass it, it may still flex and then crack your fiberglass work...don't take a chance, weld it up and be sure it won't crack later on. Just my opinion. Good luck and post up some pics!:bow::bow::bow:
  7. FOR MUD
    Apr 6, 2006
    2,804
    388
    Clayton Del
    Thinking the samething. I might try it this summer , got to get cage first and yes I will get lots of picts.
