Converting 1/2 ton to 1 ton.....
Discussion in '1992-Present Chevy & GMC models' started by big94gmc, Apr 30, 2005.
  1. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    I need an '88-'00 body style guru....
    My desire: To make my 2wd 1/2 ton '94 have eight lug up front.
    Question: Within this body style ('88-'98 1/2 tons and '92-'00 1 tons), are the front 2wd frames similar? Is it a direct bolt on to put 1 ton spindles onto the 1/2 ton control arms? If not, are the frames identical up front, so I could strip a 1 ton 2wd to the bare frame and directly bolt everything over??
    All the info possible as soon as possible please!!!!! Thanks, ya'll. And NO, don't suggest I convert to 4wd and use a D60.... I've thought about it, and it's just not gonna happen.
  2. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    No one???
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I was thinking, why not put in a 5 lug 60? Or you want a FF?
  4. originalspanksta
    originalspanksta 1/2 ton status
    Jan 31, 2005
    147
    Philadelphia
    one ton frames/suspension/spindles etc are all different i think. If you are serious about this i would look for an 8 lug 3/4 ton. I think all that stuff will swap, because the frames are similar on the 1/2 and 3/4's .
    However, i highly recomend the sas 4wd swap myself, (even though you said no) :D :D :D its easier than you think.....
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    He wants to use it as a tow rig. I think your best off to sell it and get a 3/4 or 1 ton, the frames are different then a 1/2 ton.
  6. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    Don't want to sell....sentimental value....can't get rid of the truck.
  7. tlarsw
    tlarsw 1/2 ton status
    Jan 12, 2001
    270
    Cameron, NC
    1996 c2500
    I don't know if it would work for you or not, but I have a complete 1996 C2500 8 lug at the house that is being parted out for a SAS 4wd coversion on a 4wd frame. All the 2wd stuff is there (suspension,brakes) it even has anti-lock. There is some frame damage that's why I'm not going to use the frame. If you want I can get some pics so you can see if it might work for you or not.
  8. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    I want to bring this back up to the top.... Any other suggestions/ideas?
  9. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    easy find. look up part # for b/j at store if same then in luck. but frame is big diffrence much thicker than 1/2 -3/4 ton 1 ton 2 times thicker. now hd chassie dont ask me?
  10. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    That reads like its in code.... :haha: I can't figure it out.... :D
