converting 14b to 6 lug??
Discussion in 'The Garage' started by smprider112, Jun 30, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    is there anyway...shy of using those wheel adapters to convert a 14b FF to 6 lugs?? I looks like just the drum would need to be swapped out, but with what other drum? Dumb question but would the one off my 10B work?? I havent compared the 2 yet so if thats an obvious no, please dont yell /forums/images/graemlins/whistling.gif. The only reason I want 6 instead of 8 is my less then one month old wheels are 6 /forums/images/graemlins/doah.gif anyways any help or info on this would be GREATLY appreciated. /forums/images/graemlins/peace.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes it can be done. The wheel hub on the 14bff must be machined down on a lathe so it will fit threw the hole on 6 lug rims and then the wheel stud holes must be drilled in the wheel hub and brake drum. Or at least that is what I think was needed to do it.
    If you go this route it may be a convinient time to swap in disk brakes on the 14bff so you could use the stock chevy 1/2 ton sixlug rotors and not have to drill the brake drums.
    Harley
  3. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    damn the first part sounds like alot of work...but I never thought of doing the rear disc conversion with 1/2T rotors...I may have to look into that, since it will be a better upgrade over drums. /forums/images/graemlins/peace.gif
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Personally I'd use the adaptor. The'll line your rear tires up with the fronts. /forums/images/graemlins/thinking.gif
  6. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    They would have...if it was a truck 14bolt /forums/images/graemlins/doah.gif but its outta a van so it will now be even wider with spacers....I guess since it sounds harder then I wanted I can just buy new rear wheels...they where only like 60 or so each...hey anybody need some chrome 15x10 wheels? rears only /forums/images/graemlins/whistling.gif /forums/images/graemlins/thumb.gif
  7. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    Both front and rear axles should have the same amount of lugs or you will have to have 2 spare tires or none.
    <font color="green"> Later,
    Allan Greenblazer </font>
