Converting a floor jack to Air over
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Apr 13, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I picked up a 4 ton floor jack for cheap. Its got some missing broken handle parts. I work with alot of pneumatics at work and found a on/nuetral/off air foot pedal. I figure I could make a air over jack out of what I have. Big question how do I do it? I think a air over hyd system would be better(and safer) than just air. Anyone?
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5 [​IMG]
  2. Cavalry
    Oct 1, 2000
    978
    anyone?
    Luke
    84 K5 [​IMG]
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Hey, what's up with the name? Were you in/are the Cav?
    "Liberals ain't mean, they just don't have any common sense!"
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    This would be difficult to do. Air pressure is normally about 100 psi. Not sure what pressure the jack is designed for, but I will guess 800 to 1000 psi. That means that if you want to retain the lifting capacity of the jack, you need to bump your pressure by about 5 to 10 times. This is done in air over oil hyd. systems using a multiplier. The multiplier can be a cylinder with an area on the air side 5 to 10 times the area on the oil side. Now on the oil side, you have to have enough oil capacity to stroke the jack cylinder full stroke. This means that you need a muliplier device with a lot of stroke, or it has to have a reciprocating function similar to the original jack handle (many strokes of the handle to get full stroke on the jack). I could keep going with this, but the bottom line is that it would not be a simple undertaking.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  5. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    If you need that much PSI, couldn't you just get a pressure booster? I used one on a project at work that was a very small one that boosted 100PSI to 250PSI. I know that you can buy them for very high PSI, but can't recall the company that makes them.
    [​IMG]<A target="_blank" HREF=http://www4.ncsu.edu/~brschoch>http://www4.ncsu.edu/~brschoch</A>
