converting a q-jet to elec choke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jul 26, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I want to convert my quadrajet to electric choke because i run vortec heads and there is no provision on the manifold for the heat spring type that i have. does anyone make a kit to convert them, its a 1973 model.
    Check out my 73 K5 <a target="_blank" href=http:// members.theglobe.com/xnoahx/73k5.htm > members.theglobe.com/xnoahx/73k5.htm </a>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have herd that the newer Q-jets are better for offroading than the early ones that you and I have. For that reason I was thinking of just getting a newer carb from a J/Y rebuilding it and swapping it in. My choke is just wired open at the moment (which I can only do because of that wonderfull SoCal weather).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  3. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
  4. Grim-Reaper
    7,385
    Atlanta
    no kit available that I'm aware of for the divorced choke your truck should have.
    The newer heat riser deal with the pip and the choke bowl housing (around 77 or newer) is a easy bolt on deal. Converted my 79 to electric. You will need an oil pressure switch off a newer GM with electric choke and the electric choke element. You need to put some heat shrink on the fork that the bi metal spring engages but that's it.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    Grim-Reaper
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I have heard reports that NAPA and J.C. Whitney both sell kits to convert divorced choke Q-Jets to electric - I have never seen either in person. The best route is to do what I did - get a hot air style ('75 or later) Q-Jet, and use the factory parts to convert it to electric choke.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  6. dyeager535
    26,982
    191
    Tried to put electric choke from an '82 K5 on a '74 Q-jet. Won't work. After much wasted time trying to get it bolted up (different diameter bushings for stuff, etc) ended up just putting the whole '82 K5 Q-jet on the 454 instead of the older carb.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
