Converting a TBI engine to carb whats gotta be done???
Discussion in 'The Garage' started by CaveBlazin, Dec 29, 2003.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Im getting a 350 tbi engine I need to know what its gonna take to put this in my K5. I have a new intake for carbs is there gonna be any difference or is this a bolt up thing? Any suggestions welcome /forums/images/graemlins/thumb.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    If that is the right intake for the later heads, then the carb and a good vacuum advance distributer should set you up.
  3. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    If you have the centerbolt heads, you need a different intake..Also you'll need to remove the fuel pump plate and get a mechanical pump and push rod.. What else am I missing here? /forums/images/graemlins/thinking.gif
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    It would take a brain removal for me to put a carb on a tbi engine. Why are you not keeping fuel injection?
  5. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    I have a 86 with no tbi and brain Im putting in a temp engine until my 400 is complete and the settlement with Forward Air is DONE /forums/images/graemlins/angryfire.gif other than that, that should be it..
  6. dyeager535
    26,979
    I assume the "early" TBI engines still have the cam lobe to drive the fuel pump since it hasn't been brought up?
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Make sure the block has a provision for a mech. fuel pump.... Some blocks did not and you have to use an electric fuel pump...
  8. nvrenuf
    Jan 7, 2002
    13,078
    246
    Mobile, Al.
    You can use the OE electric pump but you'll need to get a fuel pressure regulator with a provision for a return line.
  9. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Hmmm sounds like alot of work....
  10. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I think you will need a new gas tank as well, the baffels and pumps are different IIRC
  11. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    I did this a couple of months back and mi block came w/ the fuel pump lobe. It was off a 89 K5
  12. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Well Im just gonna get an older engine just got a deal on one thats carbed after finding out how much of a pain in the ARSE the other way would be. Thanks for the help all /forums/images/graemlins/thumb.gif
  13. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    What about wiring? What all has to be changed there?
  14. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    So how is the great battle of forward Air going for you? /forums/images/graemlins/mad.gif
  15. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    We did the same thing. I put a sb400 in my 89 and my 89 350 in my bro's 77. We used a mechanical fuel pump with no problems. We did use the heads off his old engine though with a Performer manifold. Only difference I know of with these "newer" blocks is the one piece rear main seal and the dipstick is on the opposite side.
  16. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Im awaiting a call back from them I sent off my settlement request now just waiting.......
