Converting Diesel Burb to Gas Motor??
Discussion in 'The Garage' started by PhoenixZorn, Mar 20, 2006.
  1. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Any ideas on how much work is involved with wiring and other conversion stuff? I can get a complete diesel burb minus the motor for $300 and I'm thinking about puting my 355 in it... I need a rundown of the cost. The burb is an 82 4x4 with TH700R4 and NP208 with I THINK 3.73 gears. I'd be transferring my motor, SM465 and NP208 from my 86 K5.
    Thanks guys.
    P.S. I'd be able to do all the work in my shop, but I need to have a rundown before I even think of starting the project. My other option is if one of you guys has a 6.2 for sale for dirt cheap that still runs. The t-case is junk in the burb, which is why I'm moving the tranny and t-case together.
  2. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    ttt... need help here guys...
  3. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    meh... one more time....
  4. freeflow
    freeflow 1/2 ton status
    Nov 6, 2004
    274
    alexandria, minnesota
    shouldnt be to spendy if u already got a motor to throw into it.
    Just the motor mounts and tranny mount, and if its gonna be carbed dont need a ton of wires anyway. It would cost alot less than buying a 6.2 to put in there.
    brad
  5. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Indeed it would... since I already have the engine... I was under the impression that the 6.2 and 350s had the same engine mounts... or is that the 6.2s and big blocks? I have no problem relocating mounts. I guess the biggest expense is going to be replacing the gas tank, getting a new intake and carburator (since the other one is melted to the intake...) and running new fiel lines throughout the truck. I would also tend to think I'd need a new Tourque converter if I stick with the automatic, but I'm still leaning towards the SM465 out of my Blazer. The last thing I'd need to worry about is drifeshaft length, since the SM465/NP208 combo is about six inches shorter than the TH400 or 700R4/NP208 combo.
    Here's the rundown so far...
    82 Suburban Chassis and Body minus engine - $300... The truck is solid, I was going to buy the whole thing for $1000, but my boss couldn't wait for me anymore and sold the motor out of the truck. There is common area rusting, rockers, door bottoms, but nothing a little grinding and filling can't fix. The interior is super clean, and would be worth the $300 even if the body were falling off.
    Replacement 40 gallon gas tank - $140 from LMCTruck
    Sending Unit for 40 gallon tank - $60 from LMC
    Fuel Lines - about $150 for everything I need unless I can reuse the diesel lines after flushing them...
    Quadrajet - No less than $350 from what I've found so far unless I buy a couple of junkers and rebuild them.
    Intake - Edelbroke Performer likely, other suggestions welcome... - $100
    Top end motor cleanup... new valve guides and replace any other parts that look to have any fire damage - $300-400
    Front and rear driveshaft alterations at a driveline shop - $100 each.
    Clutch mechanism and transmission tunnel for SM465 - $50 junk yard.
    Other possible options are taking a long leaf out of my Blazer spring pack to put in the rear of the Burb as an add-a-leaf, and taking the rest of the spring packs from the rear of the Blazer for the front of the Burb. The 32" BFG A/Ts would go on the Burb too. These are free, minus any modifications I have to pay for to get it all done.
    So the rundown...
    $300
    $140
    $60
    $150
    $350
    $100
    $400
    $100
    $50
    _____
    $1650
    $500 - Incidentals
    _____
    $2150 total cost to drive the 82 Suburban.... plus gas... :(
