converting from TBI to TPI
Discussion in 'The Garage' started by solowookie, Nov 29, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I've got a chance to get my hands on the following TPI parts; upper plenum, manifold, runners, fuel rails (needs front crossover tube), fuel pressure reg, and 22lb/hr injectors.
    I'm curious if I can use my TBI harness / sensores (and computer) to convert to TPI.
  2. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks for the links... I'm definitely looking through this stuff still.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Get a 730 ECM and harness. It's easier and cleaner than trying to use the TBI harness.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There is a company called Street &amp; Performance that sells an interceptor harness to convert TBI to TPI. You can reach them by phone at 501-394-5711 or e-mail at S-P@juno.com or check their web-site at www.tunedport.com. I hope this helps you. I have used their wiring harness for a TPI swap before and it was a nice clean factory style harness with all the correct GM connectors and color coded wire.
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    actually I had just found their website stuff. does this mean I can use the TBI sensors??? is there any other sensors I would need then what the TBI comes with?
    they have a pretty good price on converting the TBI harness with a new ECM &amp; custom chip.
    I'm not even really looking for a TPI system for my blazer, but I'm looking for one for my hotrod project. I stumbled across this, and thought if I could convert my k5 maybe I'd get some better heads, and convert it to TPI.
    what's a complete, but untested 305 TPI worth? what's the differences between the 305 &amp; the 350's? also - can a MAF system be make to work with a custom chip?
