Converting headlights
Discussion in 'The Garage' started by K5Greek, Apr 26, 2006.
  1. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    i want to convert my headlights to halogen. who sells a kit that has both low and high beams? i found one on jc whitney but it only sells a pair. wasnt sure if i have to buy 2 pairs for both low and high beam, or is it a seperate thing?
    **EDIT** or does anyone know of an HID conversion either?
    http://www.jcwhitney.com/autoparts/Product/tf-VehicleBrowse/s-10101/Pr-p_Product.CATENTRY_ID:2003804/showCustom-0/p-2003804/N-200002259+111+1991+600009403/c-10105
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I think the 91's use the 150mm housings, but you need to check to be sure. http://www.rallylights.com/hella/headlamps.asp That will convert you over to H4/H1 headlights, I did it to mine (diff headlight setup, mine are stacked lights) and the difference is awesome.
  3. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    cool thanks, im gonna have to look into that
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    If you are referring to your your '91, your headlights are already halogen, they are just the sealed beam version....
    i am thinkin you want to convert to the composite setup, with the replaceable bulb (from behind)
  5. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  6. crometooth
    crometooth Registered Member
    Aug 21, 2004
    14
    I used the lights from JC witney for my low beams, they work great but the quality isnt the greatest (go figure). I dont think you should use them for high beams though, the pattern is pretty wide... Unless you only use them off road.
    Headlight relays are mandatory after installing the H4 conversion, They draw way more current then my old sealed beams.
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Also consider buying the European style headlight lenses. Those things are simply awesome.
    My 77 has a set of European style H4 lenses with 100w/85w (high/low) drivers in them, and they are simply incredible, midaswell be driving with the sun on your roof!
    However, being the European type lense, they don't irritate people at all when you are on low beam. I've never once been highbeamed unless I forgot to come off highbeam (and trust me, you gotta be quick with 100 watt highbeams, you get highbeamed in a real hurry if you don't, lol)
    And as mentioned, relays, and a wiring upgrade is manditory with big driver's like mine. I wired my 77 with like a 8 gauge wire, which is overkill, big time, 14 gauge would probally be fine. My relays are 40 amp, again, overkill, but I happened to have a pair.
  8. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    They dont make em for the 89-91 style lights.
  9. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    How about these for the hi/lo lights:
    http://www.rallylights.com/hella/150mm.asp
    Then adapting some 150mm driving lights for use in the hi beam holes?
  10. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    SierraClassic was talking about euro lights. K20 posted up the same link you did. I really like the hella conversion. It is now on a list of things to do.
  11. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    i was under the impression though that once you convert it, it wont be sealed anymore. i could be wrong though.
  12. 4xcrazy
    Oct 31, 2003
    9,472
    5
    what am i missing here?:confused:
    when i mean seald beam version, thats the glass sealed units, the composite units are the plastic housings that require the replaceable bulb that plugs in from the back.....
    the composite units are sealed, somewhat, with a rubber o-ring, the the housing is usually glued together.
  13. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    i mean once i did the conversion, i wouldnt have sealed beams anymore, id have composites. like i said im not sure, thats just what i thought
