Converting Nitrous bottle for CO2 air ?
Discussion in 'The Garage' started by Bushwhacker, Feb 9, 2007.
  1. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    Anybody done this? I just got my hands on a brand new Nitrous tank and wondered how hard it would be to use for an air system. Could you just get the reg and hose stuff?
    thanks for any help you can give!
    Clay
  2. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    hay thats a good idea, I have an old nitrous bottle that I could have recertified and use too. is this doable people??
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    You have to change the valve too, so you can really only use the tank!
    So yes its doable.
  4. Bushwhacker
    May 13, 2002
    796
    What am I looking at as far as cost would ya think? I was thinkin of getting a setup you sell, but if I could save a little money and convert this one it would be nice. Would you have the parts to do it?
    Thanks,
    Clay
  5. 81jimmyslt
    Jun 5, 2003
    1,643
    No we don't have the parts to covert the bottle, take it to your local oxygen or welding shop. They will have no problem helping you with the bottle. You need to get it filled anyway.
    As far as the regulator, hoses, and mounting brackets we got you covered!
  6. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I have an old Nitrous bottle around here some where I have a new side project:D
  7. Bushwhacker
    May 13, 2002
    796
    81jimmyslt, thanks! I will definitely give you a call on the other parts. I'll take it and see about getting it fixed up.
    Thanks,
    Clay
  8. goldwing2000
    goldwing2000 Guest
    What pressure is a nitrous bottle rated for?
    CO2 tanks are in the 2000-3000 psi range.
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    One ref I found said 700-800 psi is the best performing NOx bottle pressure.
    Found this on CO2 pressure on a paintball site:
    "What's the pressure in a CO2 tank?
    As long as there is liquid in the tank, the pressure in a CO2 tank is determined ONLY by the temperature. At room temperature (70 degrees F) its about 853 psi."
  10. goldwing2000
    goldwing2000 Guest
    I suppose you could fill it to any pressure you wanted, really.
    I only have experiance with industrial CO2 tanks, though. Much higher than 853psi. That's why I was asking.
