Converting power windows to manual
Discussion in 'The Garage' started by laketex, Mar 24, 2004.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Ok, search sucks. Either there are 50 posts a day about this topic or somebody has it in their sig....which is a crappy sig line, btw! /forums/images/graemlins/angryfire.gif
    Anyway, I have power windows that dont work and I'm planning on swapping in some manual regulators and cranks this week. I've got the regulators and cranks already. What else do I need to complete the job? How do I know where to cut...any tips? I'd like to get this done soon cause it sucks to cruise around in the spring/summer with my winders rolled up. Thanks for any insight you may be able to provide..
    And btw, any wires I should make sure not to cut??? /forums/images/graemlins/rotfl.gif
  2. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    Do you have power locks, if so make sure you don't cut those wires if you are keeping them /forums/images/graemlins/doah.gif/forums/images/graemlins/whistling.gif
  3. laketex
    6,220
    North Texas
    Yup, i have power locks, but I'm pulling that bs out too...they work just like manuals now and I like it that way. /forums/images/graemlins/eek.gif
  4. dyeager535
    26,982
    191
    Don't cut ANY of the wires. Pull them out the way they are supposed to be (connector under the dash) and sell them to some other unfortunate soul that needs them. My opinion anyways, there is call for these things.
    I believe everything is in the door already (for the mounting, etc) but you'll need new door panels if you want it to look good.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah, I agree just unplug the harness. No cuttin required. Other than that it's a bolt-in operation. Take out the lock actuators, it'll make it easier to unlock/lock if you want them manual. You can just take out the window switch on the door panel and the crank rod can stick through that, it doesn't look too bad. /forums/images/graemlins/grin.gif
  6. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    My last truck was an 85 1/2 ton pw. pl.
    On it I was able to just un-bolt the pwr. win. motor get it out regulator and all
    The manual crank with regulator just bolted right into the same spot no problem
    The crank even came ouy the pw.switch hole in the pannel
    IT looks harder to do than it really is
    BTW don't cut the wire harness , just unplug and leave it in the bottom of the door
    Hope this is understandable? /forums/images/graemlins/thumb.gif
  7. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    yes like me sell them to me bro
