converting tbi to a carb
Discussion in 'The Garage' started by SEREsolution, Aug 17, 2005.
  1. SEREsolution
    SEREsolution Newbie
    Dec 30, 2004
    3
    albuquerque
    does enyone know how and where to get info on how to convert a 350 that had tbi to have a carb.
    thanks
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i believe you will need a new manifold...and the carb of course...buy a edelbrock intake and carb and it should work pretty easy. you already have all the linkages you need.
  3. SEREsolution
    SEREsolution Newbie
    Dec 30, 2004
    3
    albuquerque
    carb
    i not sure the best way to wire it up if someone has done it help would be much apprecited!!!
  4. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    can still use stock pump need return line hooked up did you check on just getting a higher flow oe style throttle body?
  5. dunehopper502
    dunehopper502 Registered Member
    Mar 1, 2004
    56
    MI, U.S.A.
    i converted my 94 silverado tbi over to carbed big block and it wasnt to bad..
    first youll need a fuel pressure regulator to lower you 12-15 psi down to about 5-7 for the carb, and youll need a big cap hei dist with vacuum advance instead of your small cap dist with the igniton module,,
    id recommend you neatly put aside all your wires and connectors from the original tbi incase you decide to go back to stock,im glad i did for selling reasons. and of course the intake and carb,recommend no bigger then a
    600cfm unless you have internal motor mods done...also beware of the emission laws by converting over too they gave me a hard time..i havent seen any books on how to do this just trial and error for me..good luck
