converting tbi to carborator
Discussion in 'The Garage' started by kiken88, Oct 3, 2006.
  1. kiken88
    kiken88 Newbie
    Sep 11, 2006
    Eckert Colorado
    How is a electric full pump with a edelbrock carb?
  2. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Put the TBI back on? Being in Colorado, after I went TBI, I'll NEVER drive a carbed rig again.
  3. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    Recheck all your grounds and cables.
    pretty sure the negative cable goes from the batt to the front of the block, and there is a little ground wire that connects the front clip to the frame rail, and then a copper strap from the firewall to the back of the head.......and i think there is one more copper strap but i forget where i goes
  4. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    that is the dumbest thing I have ever heard, TBI is so much better!!!
  5. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    can't agree with you there... having wheeled with both a q-jet and TBI the TBI was only slightly better at angles than the q-jet.
    kiken88, when you say "getting hot" do you mean hot as in 12v+ or hot in temperature? or both?
  6. kiken88
    kiken88 Newbie
    Sep 11, 2006
    Eckert Colorado
    hot in temp the only reson i'm doing this is i need it back on the road soon and rebuilding my 88 block and heads it had 500,000 miles before oil pump shaft retainer broke
