Converting to 1 ton, not an axle question
Discussion in 'The Garage' started by sled_dog, May 6, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    been there done that on the axle swap end of things, what about converting the suspension to one ton levels? When I bought my last vehicle I should have gotten a 1 ton pickup. Instead I bought a 3/4 ton 2wd. It gets good mileage but thats all its really good for. Its got nice power too but yeah thats just trouble. Thinking I should take my 89 Burb and truly convert it to 1 ton and a crew cab with a tiny bed for a tow vehicle. Anyone ever done this or know if its doable? I don't know the frame difference between 3/4 ton and 1 ton if there is any.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just stiffen up the rear springs and put a full floater in it and you've got a 1 ton, basically. The 1 ton brakes are bigger, but a disc swap would fix that. /forums/images/graemlins/thumb.gif
  3. Martin460
    Martin460 Registered Member
    Feb 25, 2003
    21
  4. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    The 3/4t Suburban frame is marginaly stronger and heavier.
    It may be better to locate a 1ton frame and build from there.
    But if you use the exsisting frame, just reinforce it, and use the 1t springs or make custom packs to get the GVW desired.
    I've seen a 1 ton dually 2wd burb before, guy took a 3/4t and swapped out the entire suspension for 1 ton pieces, even the contol arms and all steering parts up front.
  5. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    There is actually a frame difference between 1/2, 3/4, and 1 tons?
    What is the difference?
  6. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    IIRC, the 1/2's and 3/4's have the same frames, and the 1-ton's are thicker. Course, /forums/images/graemlins/k5.gif's are only available in 1/2 ton, and /forums/images/graemlins/burb.gif in 1/2 and 3/4 ... so the only time you'd see a "real" 1 ton frame is in a pickup.
    Hmm. No mention of it here
    though. Donno.
    -- A
  7. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    If I recall correctly the diff was in the thickness of the frame metal itself, but I may be mistaken and thinking of the 1 ton vs 1/2 ton too.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I personally think swapping to 1 ton springs would make it ride rough. I also think swapping frames would be a waste of time.
  9. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I went "1-ton" on my Burb.
    To make the front brakes 1-ton, you need lower balljoints, splindles, rotors, calipers, and brake hoses. I also changed the coils (only because I had them handy, and they were 0.020" thicker). The rest of the front suspension is the same. 3/4-ton master works, but when it craps out, I'll be putting on the 1-ton one instead. (Not sure if there even is a difference.)
    Sure the frame isn't as big as a 30-series pickup, but that won't affect towing. The taller frame channel is for payload; i.e. heavy stuff piled on top of the truck.
    I think it'd be more fun to hack open the back of the Burb and build a bulkhead than swapping on a crewcab cab. /forums/images/graemlins/thumb.gif
    This little how-to project is for a K5, but I'm certain it could be applied to a Burb also.
    http://www.roscommonequipmentcenter.com/projects/rec62.pdf
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    If I were to keep my Burb I would do just that. Not that same thing(I did that to my 84 K5 before I chopped it up, but rather graft the rear of it on right behind the doors. But I think I am going to sell the burb. I want a Crew Cab 4x4. And yes I mean a crew cab long bed with big lift /forums/images/graemlins/smile.gif whatever just keeping my 97
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    the main differance between one ton is the frame. suspension is the second. the vin is the third.
    you can upgrade the front and rear springs, but your frame is still not rated for a true 2000lbs.
    grant
