converting to a 5 speed
Discussion in 'The Garage' started by S. Burnham, Jun 19, 2005.
  1. S. Burnham
    S. Burnham Registered Member
    Dec 12, 2004
    64
    hattiesburg, ms
    i was wondering if anybody has converted there 80,s model k5 to a 5 speed manual?
    if so what is the best and easiest devorced t-case to use to do the job?
    i was thinking of finding a wrecked vortec 2wh. vortec truck with a manual and so i could get the engine and trany cheap. i have a 88 k5 but dislike the auto trans. any input from you guys would be appreciated.
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I'm curious as to why a divorced setup?
  3. S. Burnham
    Dec 12, 2004
    64
    hattiesburg, ms
    well i don't know a lot about t-cases. i was under the impression that all the late model trucks with the vortec moters used electric activated t-case, and the front shaft came off the wrong end. can you shed a little light on this for me.
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    I'm certain it could be done pretty easily with a divorced case. I am not sure, but you may be able to buy an adapter to bolt a pass side drop t-case on, or you could get a ford diff and move the perches to use the stock driver's side drop t-case.
    However, the divorced case would probally be the cheapest option (as far as I know) and would probally work pretty well too.
    There are a couple different divorced cases, but I'd assume a Divorced 205 from a 74 or prior dodge, or an international would be the most common.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    All IFS Chevy's are driverside output but if you have the NP208/241 (don't know which model GM used in 88) from your blazer, stab it onto whatever transmission you want to use, I'm not 100% on this but I believe all new model manuals have a fine spline output so your T-case should bolt up. I'm guessing the tranny you want to run is an NV4500
    almost forgot, not all t-cases are electric, if there is a shift lever though the floor then the t-cases is mechanical, the center axle disconnect works off a solenoid when you shift into 4wd but this isindependant of the t-case
  6. S. Burnham
    Dec 12, 2004
    64
    hattiesburg, ms
    i found my donner truck. it is a 92 2 wheel drive with a 350 and a 5 speed. it has been totaled. i am going to be able to pick it up for about 5 or 600 dollars. does any body have any else have any good advice or recamendations for my project.
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Best advice is to not buy that as a donor for a 5 speed...it would have a weak Getrag 5 speed.
    The ideal 5 speed conversion is to a NV4500 found in 93 and newer 3/4 and one ton Chev's. They are 32 spline output in the 4WD versions and got the NP241 behind them from the factory. Of course they were drivers side drop, but the passenger drop 241's from 89-91 bolt right up. I am pretty sure a 32 spline 208 will bolt right up too.
    Rene
