converting to a 67-68 front end?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by jughead, Aug 23, 2006.
  1. jughead
    jughead Registered Member
    Feb 5, 2006
    96
    Long Island, New York
    What goes into converting the front end? Will I only need the hood and grill?
  2. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    You will need a hood, grill, turn signal lenses, fenders (67-68 are different than 69-72 Chevy but the same as 67-72 GMC) and you will also need a 67-70 bumper if you are keeping a stock style bumper.
  3. jughead
    Feb 5, 2006
    96
    Thanks....everything you listed will bolt right on to existing hardware?
  4. bigblock72
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    The frame, cab and radiator support are the same so the bumper, fenders, hood and grill will bolt up assuming you have all the necessary parts.
  5. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
  6. 68on44s
    68on44s Registered Member
    Jan 30, 2006
    42
    arkansas
    Im running a 67 truck on a 76k5 chassis and would rather have a 69-72 front end.. if someone wants to trade my front for there newer front im game.. Im in arkansas and my front isnt perfect by no means. it would be good for a trail rig. previous owner hacked up the headlight area on the core support so they could run dual headlights, but the outside grill is fine. If i use it im putting kc lights in there.. im going to taper this soon so if anyone is interested.. hurry
  7. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    So if I'm reading this right, a 67-68 GMC truck front end will work on my 72 Jimmy?
    The reason I ask is I've got some fender / innerfender damage that either needs to be replaced or fixed. Found a 67-68 GMC front clip that looks straight and price is right. Don't want to waste my time though if it won't work on my 72.
  8. 6872xtc
    6872xtc make mine modified Premium Member
    Sep 16, 2008
    1,576
    566
    Palisade,Colorado
    I found out the hard way that the 67-68 radiator core support IS NOT the same as 69-72. Also the center brace to the grill and hood latch are different. The headlight buckets are specific to grills. The 69-72 buckets are spot welded to the core support and the holes in the core support are different. The powder coat guy liked doing two core supports for me though!!
    But as far as I know, the GMC's were all the same fenders and core support.
  9. chalet2506
    May 9, 2006
    4,931
    Skeddadlin
    Cool. Thank you.
  10. 63chevyll
    63chevyll 1/2 ton status
    Aug 13, 2009
    4,517
    5
    Colorado Springs
    You sir are correct, 67, 68 rad supports are different also
