Converting to a Dually?
Discussion in 'The Garage' started by Pookster, Jul 25, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Someone correct me if Im wrong-
    But is the wheels of a dually truck ofset just so, so that the spare would be usable on every axle?
    Also, if you used a hub spacer on the front of a SRW truck, and then used a dually wheel on the front- Would that be effectively the same?
  2. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    They should be, yes. You'll note that the lugs on a dually front are right at or outside the outer edge of the tire; so yes, the wheels have hellish offset when compared to single-tire trucks.
    You can get kits to do this aftermarket, however, and some of them are very JC-Whitney-esque and do weird things with spacers and god-only-knows-what. Haven't seen a dually /forums/images/graemlins/k5.gif yet, thankfully, but I've seen several dually /forums/images/graemlins/burb.gif's.
    You'll also need to run fairly skinny tires to fit two, even in the extended fenders.
    As for
    As long as the hub spacer made the track width on your front axle the same as a dually track width, you'd be fine. That's a hell of a spacer though -- hafta be like 4" thick or something.
    -- A
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Need a set of dually axles and wheels? Let me know.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    It would actually be closer to a 7" spacer /forums/images/graemlins/thumb.gif
  5. dremu
    Feb 27, 2000
    15,968
    461
    Waaaaaaaaaaa! Okay, so my math sucks... it was early in the morning. Still is, actually.
    To the original poster: considering that very few people want dually axles, I would think you could find a set CHEAP. You could swap just the outers if you didn't want to do the whole axle, in front. In back I think it'd be easier to swap the whole thing.
    -- A
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    YOu know how to tempt someone! tell me more. /forums/images/graemlins/smile.gif
