Converting to Disc Brakes on Front? Help?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by joryyroj, Jul 29, 2003.
  1. joryyroj
    joryyroj Registered Member
    Mar 13, 2003
    32
    Wylie Texas
    I have not been able to find wheel studs long enough to hold on the front wheels for my 1970 blazer. Everyone is telling me to convert to Disc Brakes instead of Drums.
    I was going to call around to some junk yards to find the parts I need to accomplish this, does anyone know what I will need? I am really not that mechanical but I am trying to learn with this blazer. This brake conversion may be a little out of my league. If anyone has any tips or parts list please let me know. I am starting from zero so any advice would be great.
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    The easiest way is to get a front axel from a '71 or '72. Sorry, don't know much else that can help. A good autoparts store (say away from Schucks, etc) might be able to help you find a longer wheel stud.
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Just pick up an "entire" axle from a '71 K10 or a K5. Disc brake's were standard on them. Also grab the master cylinder, and brake booster.
    Then just swap the axle's. Pick up a set of new "U bolt's"
    and a set of brake hose's for the caliper's.
  4. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    I think the easiest way is to swap in a disc brake axle with the same gears as your current set up. Have you ben over to www.67-72chevytrucks.com yet. It's a pretty informative site for these trucks.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would sugest a 73-up axle to swap in. They came with larger (297) u-joints in them. Not the weak (260) ones that came in our trucks.
  6. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    I'm sure you know more about this than I do, but I thought I heard it was the smaller style until 77. Did I hear that wrong or am I just pulling facts out of my ... again?
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    The change to larger U-joints was '73. '77 was the change to a larger wheel bearing and internal lockouts /forums/images/graemlins/thumb.gif
  8. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    The easiest thing would be to swap in a '71 or later axle as mentioned already. But if you can get the parts (bearing hubs, rotors, calipers, caliper mounts, brakelines), you can put them on your current axle. You will have to do a good bit of grinding on the knuckles to get the calipers to move freely, but it's nothing that will compromise strength. The only thing I can't remember is if the spindles are different between drums and discs. I converted a '70 Dana 44 to discs and ran it for a long time until I got another Dana 44 with 4.10s for really cheap. Hope this helps.
    Will
  9. 71blaz
    71blaz Registered Member
    Aug 1, 2002
    86
    southwest colorado
    I swaped to disks on a 70 sub that I had and replaced the master cycl., proportioning valve, front brake line all the way from the pro-valve to the frame, It is a different diameter for discs and drums.I also found out that the hub from a drum will work for discs with a small amount of machine work, they are almost identical.I had a doner front end that I used the dust shields and caliper mounting plates from.Good luck /forums/images/graemlins/grin.gif.
