converting to Fuel Injection
Discussion in 'The Garage' started by Redfrog, Apr 28, 2002.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I am rebuliding my 350 and adding Tbi and need to know the following
    How big of a cam can I run with out messing with the computer?
    And how much Compression can be run with out messing with the computer.. or is compression even a matter
    Is there any onther factors that I should take in to consideration for the swap
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    In my opinion these are the max # you can run on a stock chip.
    Lift .445 I know this will work with the stock chip. but I have heard you can go higher with the lift
    Duration 214 degrees max
    Duration is more important than lift. You will loose vacume with higher duration numbers and that will mess up the readings from MAP sensor.
    I also would go no more than 9.5 to 1 on the compression.
    If you are going to modify a TBI engine I recomend tou get an adjustable fuel pressure regulator. The stock one in the TBI is usually set a little low. With the adjustable regulator you can get the pressure up to 13# and give the engine a little more fuel.
    Go to <a target="_blank" href=http://www.thirdgen.org/newdesign/tech/>thirdgen.org</a>. Scroll down the tech articles and read: Ultimate TBI parts 1 and 2. and the article about the adjustible fuel press regulator. Lots of good stuff there to get more flow out of your TBI.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've been consittering converting to MPEFI. I just don't have the funds at the moment.
