Converting your Blazer into a P/U (instructions)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjbear, Nov 21, 2003.
  1. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    I found something intresting today. For those wanting to convert their K5s to pick-up cabs. http://www.roscommonequipmentcenter.com/projects/rec62.pdf It contains a description at the begining, then pics and finially a measured drawing. Kind of like The New Yankee Workshop for K5s. The goverment likes these kind ot projects for some reason. Ever seen the steel tops on an M715? Same knind of deal.
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Isn't there already an aftermarket conversion for doing this?
    Also, didn't anyone involved with this project think to swap the heavy K5 tailgate with a pick-up gate to gain a little more potential payload?
    Rene
  3. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Sounds like a good plan for the military. I just don't see why anyone else would want to do such a thing to a blazer. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    What's the point? If you want a pickup.....then get a pickup!
    One of the best things about K5's is the versatility of them. With no modifications you can have a "cargo hauler" or a "people hauler". If all you are worried about is hauling cargo then go buy yourself a truck and save the trouble.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I agree with you but many don't, they like the short wheel base of the K5 but want a closed cab and a bed so they do it.
    A few in my club have done that.
    /forums/images/graemlins/thumb.gif
    FRIZZERFLY is the first I think.
    he used a WILLYS bed for the small size
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I wouldn't do it on a permanent basis but it might be kinda cool to have an extra top cut down like that. Switch them out if you get tired of things the way they are. Just use all weather stripping instead of the silicone caulk and take your time to make it fit really good. I would also make the extension out of aluminum for weight savings. Wonder what it would look like if you left 2' on insted of the 6" or so they went with. Kinda like an extended cab?
    /forums/images/graemlins/thinking.gif
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I am working on exactly that.
    I cut the rear end of a cab and I am working on the details to make it a bolt on with weather strippings.
    I didn't even go through the trouble to make the cab, just had a pickup cab laying around so I choped the rear off.
    Will post up as soon as I get time to finish it, maybe in my next lifetime /forums/images/graemlins/thumb.gif
    Too many projects, so little time. /forums/images/graemlins/rotfl.gif
  7. rebelk5frk
    Dec 29, 2001
    815
    Houston, TX
    That's all fine and good but if I remember right the difference between a K5 and a SWB pickup wheelbase is only about 6 inches.
    I could maybe see making a lightweight (easily removable) half cab setup, but it still seems like more trouble than it's worth. Besides they already have soft tops that do basically the same thing.
    I guess my opinion is moot anyway.... I couldn't do it if I wanted to.... My rollcage just won't work with a half cab type setup.
    To each their own I suppose /forums/images/graemlins/thinking.gif
  8. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I know someone whos done it.... /forums/images/graemlins/wink.gif
  9. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    why do civilians spend hundreds for a suspension that only adds about 6 inches
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's not 6 inches anyway. It's 9-10" I believe. What's you guy's stock wheelbase? A shortbed truck is 117.
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Stock K5 wheelbase is 106.5".
    I think what was referred to is the bed size, the K5 bed length which is pretty close to 6 feet.
    Rene
  12. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    I don't want a P/U. But in the winter I don't want to heat the back of the K5 either. The kids don't come on cold weather wheeling trips so the back has no need to be heated. This setup is too permanant for me, but seals much better than my fabric rear cab wall. The main reason I posted it was for that great blueprint at the end.
  13. tecton
    Dec 1, 2002
    1,553
    WV
    coat
  14. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Thats what my "truck Blazer" is... someone took a '76 K5, and a truck cab, and molded the two together to create a short-shortbed. I had wanted an actual K5, but couldn't pass it up for $600 complete and running.
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Looking at those instructions again and I think it would be cool to make the extension and instead of using sheet metal for the rear wall, use Plexiglass or lexan, something like that. Attach it with bolts and seal it up but your visibility would be awesome. Dump the tailgate and your golden. You could even use it with a roll cage. I've seen cages go through the back of pickup cabs. I think they just make the hole on the large side and use some kind of boot to seal it up. I think I just found a spring project!!
    OH, yeah it would still keep some heat in.
  16. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    You could always spend $40,000 and buy an Avalanche /forums/images/graemlins/shocked.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    This is too permanent for my taste. /forums/images/graemlins/thumb.gif
  18. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
  19. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    That's cool. But what the hell is aircraft grade Lexan?
  20. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually it should be the speed glass, that is what they use in Off road race trucks, it's basically a lexan window with the surface treated for scratch proof surface.
    It's not cheap though.
