Converting
Discussion in 'The Garage' started by win717, Feb 3, 2004.
  1. win717
    win717 Registered Member
    Mar 8, 2003
    60
    PA
    I am planning on ripping my 205 transfer case and 4spd out and replacing it a 3pd autotrans and transfer case out of a 76 blazer..What will I all need?I figure I'll need a new rad, trans crossmember,a floor shifter but not sure what else i might need..driveshaft??front/back??both? anything else I'm missing? oh yea and I'm not sure about the wireing for the neutral safty switch and the bacj up lights
  2. win717
    Mar 8, 2003
    60
    PA
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    If you get a B&M megashifter, it will come with the neutral switch and backup light switch.
    You will need a new radiator. Trans crossmember should be fine, but you will need the correct adapter and rubber mounts to bolt it on.
    I dont know on the driveshaft. Some have to be changed, some dont. Mine did not require changing at all.
    You will need the hard lines from the tranny to the radiator.
    John
  4. win717
    Mar 8, 2003
    60
    PA
    The wires that hook up to the manual tranny will they match the onces on the auto tranny?
  5. win717
    Mar 8, 2003
    60
    PA
    ttt please
