cooker
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cooker, Dec 12, 2001.
  1. cooker
    cooker Registered Member
    Dec 11, 2001
    22
    north carolina
    where can i find the plastic supports that go around the front seat belts that hold them up so you dont have to go fishing on the bottom of your truck to find it once youve seen that state trooper and remeber that youre suposed to have it on in the first place thanks cooker
  2. dyeager535
    26,979
    Wrecking yard or GM would be my choices
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. I asked the dealer about this same thing a while back and was told that it's not sold separately, you can only get it with the entire seat belt assembly...
    -Rick
    "You can have my K5 when you pry it from my cold dead hands!" [​IMG]
  4. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Rick is correct...
    Jim
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
