Coolant additives
Discussion in 'The Garage' started by trailblazr81, Jul 27, 2005.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Has anyone used stuff like Royal Purple's Purple Ice or Red Lines Wetter Water. Says as much as 30 degree drop in temperature? I understand what they are supposed to do but do they really make a noticable difference in temperature drop? :dunno:
  2. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    the additive releases the surface tension in the water. say you have a single bead of water on a plate,the surfactant will allow the bead to disapate to a big puddle if you will. I have used it before, but with most of my junk i dont know if you could tell anyway.the theory is there so it couldnt hurt. hope that helps
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Years ago when I did some roundy round racing we used the red line stuff it took our temps down about 30* on average
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I have used Redline wetter water and it worked for me.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I had a '93 Plymouth Laser that I had put Water Wetter in, to help control temps while driving (and pulling a 2K lb U-Haul trailer) from SoCal to PA in July '97. Worked great; it got hot a couple times on the climb to the Eisenhower Tunnel on I70, but never overheated.
    But when the first really cold days of fall came along in PA that year, my wife complained that the heater was blowing cold air. So I took it out for a spin and found that the temp gauge wasn't even getting into the "normal" range markings, much less into it's normal spot. Couldn't figure it out, until I remembered the WW. So I drained and refilled the radiator with fresh coolant, and it warmed fine after that.
    SOOO, YES - Red Line Water Wetter does make your cooling system more efficient.
