Coolant flush
Discussion in 'The Garage' started by 79cheyenne79, Dec 6, 2006.
  1. 79cheyenne79
    79cheyenne79 Registered Member
    Aug 14, 2005
    29
    maryland
    Is it a good idea to take the t-stat out and flush. Or replace the clogged t-stat and then flush.
  2. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I would remove the t-stat and then flush with about 5 to ten gallons of distiled water until the water comes out clean. Distilled water is cheap at Walmart Once the water is clear, replace the t-stat, add coolant and distilled water and you should be good to go.
    Also, check out this forum and it should answer all of your coolant questions
    http://theoildrop.server101.com/forums/postlist.php?Cat=0&Board=UBB37
