coolant in oil
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85Jimmy, Jan 30, 2003.
  1. 85Jimmy
    85Jimmy Registered Member
    Oct 30, 2001
    97
    Great Falls, Montana
    I almost overheated my jimmy the other day. it turns out the coolant is some how going into the oil. How could this happen? I did a compression test they are all between 170-180 and psi which means its not a head gasket doesn't it? it has a 305ci S.B. Thanks, Chris /forums/images/graemlins/confused.gif
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    could be coming from intake manifold gasket leak. I changed mine about 3 weeks ago and no more coolant in oil
  3. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    its could also be a small hairline crack in one of the cylinders. is it really hard to start in the moring? if so the cylinder is filling up with water. and you may risk bending a connecting rod and some valves, or even destroying a piston. i would either try and figure it out yourself or take it somewhere so you find out whats wrong with it before you do any major damage.
  4. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    i was goin say say intake gasket as well /forums/images/graemlins/thumb.gif
  5. 85Jimmy
    Oct 30, 2001
    97
    I got new intake gaskets today. I bought mr. gasket ones with the plugs for the heat crossover, should I use these or cut the gaskets so the crossover is enabled? the intake is a edelbrock performer eps Thanks, Chris /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    I had originally bought the mr gaskets also with the blocked ports, but went back and got the Felpro's that were open. You should cut them or go get open ones. Also, do not use the rubber ends(front and back), just use some silicon gasket sealer
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Anti-freeze in oil (Milky looking oil) is usely a head gasket or intake manifold gasket. Hope ya didn't get it hot enough to warp a head.
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I had this on a 400SBC one time, it was a hole between the water jacket and the cyl.
