coolant inside cab
Discussion in 'The Garage' started by Big GMC truck, Mar 17, 2006.
  1. Big GMC truck
    Big GMC truck Registered Member
    Aug 23, 2005
    73
    California
    What could cause coolant to leak inside the cab? How difficult to fix?
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Leaky heater core... not to bad.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Good article on the home page under tech
  4. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    One of my most hated jobs for some reason.
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    replaced it in my truck in 1 hr.... in my '86 z-28 took 8 hrs... had to take EVERYTHING out including the fricken dash!!!! and I mean.. UNBOLT THE BOLTS THAT HOLD THE DASH METAL TO THE FIREWALL!!! :doah:
    our 1996 GMC Jimmy 4 door was in need of a heater core.... $850 for a shop to do it :crazy:
    traded dat sum bish in :haha: 2005 TrailBlazer EXT now....
    I dont know why they make newer vehicles so hard to get to.... I love my '78.. nice and easy :wink1:
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep. Heater core is leaking. :( I have a new one to go into my '90 Sub right now. It was leaking so bad that coolant was dripping out from under the front passenger door. :yikes: The good news is that the part costs $23 at Autozone. :) The bad news is that you need to be a contortionist to swap it. ;)
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    If you don't need the heat, get a coupler from AZ to put the 2 size hoses together.
  8. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    On mine it was easier to remove the inner fender well to get to the two lower nuts that are below the blower assy in the engine compartment. I think I had more problems removing the core from the inner duct but its not bad. Just be careful that you dont break any of the vacuum hoses that attach to it. The tech article is real good. If your vehicle has a ECM located above the inner duct, check your connections when your done. I somehow knocked one of my plugs loose and after three months it worked its way out and the socket. It would figure it was the one that powered the fuel pump and only took 3 weeks to find it :doah:
  9. Big GMC truck
    Aug 23, 2005
    73
    California
    Do you think old, worn heater hoses could cause coolant to leak inside the truck?
  10. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    Maybe, if it was leaking right at the firewall. But as others have posted, I'm 99% sure it's the core. And there's no two ways about it, that job sucks.
  11. snoman87
    snoman87 Registered Member
    Aug 25, 2004
    88
    Edmonton, Canada
    It's possible ... I mangled the pipe on the small end of the heater core when I swapped motors. The hose wouldn't seal properly and it started to leak into the cab which made the appearance of being a heater core. If you think it might be hoses, replace them. Probably want to do that anyway when you do the heater core.
  12. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    My vote is the heater core, have fun replacing it, I would say it is one of the most miserable repairs that you can do. While you are at it clean the blower wheel, mine was really packed with crap and made a major difference in the amount of air that was moved, plus the fact the heater core was really plugged also.
  13. snoman87
    Aug 25, 2004
    88
    Edmonton, Canada
    I have also been told that putting a blower from a 92' extended cab will move more are ... don't know the truth to that or not.
    BTW: I had to pull the inner fender down to get at the lower bolts because of the diesel sound sheilding that I had.
  14. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    I had coolant smell in my cab and the hose clamps were just loose. Try that before tearing into the dash, at least for a few days to see if the smell will dissapate.
  15. Big GMC truck
    Aug 23, 2005
    73
    California
    Thanks for the info. I think it's the hoses becauses a week earlier I had tightened them at the firewall and the leak went away for a while. By the way, it only leaks about 2 tablespoons a day. If it were the core, wouldn't it leak a lot more?
  16. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I just got done changing my heater core, still waiting on the carpet padding to dry :rolleyes: . Off and on total work was ~3hrs. Probably an hour was spent trying to figure out how to get the actual heater box apart to get the core out. Gm likes to hide screws under weather stripping.
    It apparently started as a small leak cause I had been having problems with my windshield fogging, and just chalked it up to our screwy weather. Then one bright & sunny day it fogged up, reaked of coolant, steam out the vents, and a puddle in the passenger floor. Watching coolant drip out of the box sitting at redlights.
  17. rlhenry
    Mar 6, 2002
    93
    Morenci, AZ
    It all depends. I've seen them only drip a little as you are describing and I've seen them puddle up the passenger area in a few minutes after the engine warmed up. It's basically just like the radiator. It can start as a small leak and grow from there, or it can fail big-time all of the sudden. I've seen one rupture where the inlet/outlet pipes meet the core and it emptied half the cooling system in a few minutes.
