Coolant leak from Here??...wtf
Discussion in 'The Garage' started by dallassnowman, Mar 15, 2005.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    I've seen antifreeze sitting in this corner and after starting it and watching it I see it bubbling.. Can this be true?? Its right below by thermostat. I even wiped up and watched more freeze come out.....:confused: :mad: :confused: :mad: :frown1: :frown1: :mad: :confused:
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I cant quite place where that photo was taken.. CAn you get one further back or describe where it is better?
    John
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I retract all I said, I was looking at it like its a small block, sorry.
  4. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Its on the drivers side.
  5. rockspider
    rockspider Registered Member
    Sep 9, 2004
    37
    Isn't it coming from the gasket between the thermostat manifold and the block? Could just be a leaky gasket, and if that one is easy to change without dismantling anything else than the manifold itself. It could also be one of the bolts of the aforementioned manifold gone loose, because their threaded holes are open inside.
  6. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Is that where the head meets the top of the deck on the block? If so there is likely a water jacket in that area. I'm not terribly familiar with the 6.2, but a bad head gasket could cause that leaking...
    John
