Coolant leak from oilpan/cam shaft
Discussion in 'The Garage' started by blazerpro79, Jun 27, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    hey guys the seal between the oil pan and cam shaft seems to be leaking coolant??? im thinking to myself, how can coolant come from there? does coolant flow there? and how do i fix this?
  2. puckhead
    puckhead 1/2 ton status
    Jun 17, 2005
    112
    colorado
    may be a water pump to block gasket leaking and running down
  3. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Are you sure it is not coming from your water pump, and just leaking down to the area you see it. Check for a coolant leak coming from a little piss-hole at the bottom of your water pump. When this happens, it is a sign that your water pump is about to go out.
  4. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Coolant leak
    I assume by "Camshaft" you mean "Timing cover"? I would try to eyeball the water pump behind the pulley and see if you got coolant coming out the weep hole on the pump.
