Coolant leak?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Sep 10, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think I have a leak somewhere, cause my radiator gets low after a few days, and maybe 20 miles its a few inches low and I have to fill it up. There is no sign of a leak anywhere around the radiator or hoses, heater core or water pump, and the oil level is steadily declining as usual without any sign of water in it. I don't smell any coolant, and don't see any leaks...is there something I'm missing? Thanks
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    leaky head gasket? have you tried a compression and leak down test? that may tell you if you head gasket is going south.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I would have thought that, but there is no water in the oil and I don't see any signs of leaks on the side of the engine...
  4. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Just goto NAPA and get a block tester, and that will tell you if your head gasket is leaking. Its like a blue liquid.
  5. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    how does it work??
  6. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Yeah, I've never heard of that stuff.
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Figures out where it was coming from...the water pump gasket is leaking...I'm going to replace the water pump while I'm in there, since its pretty cheap and has 165K on it...
  8. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    cool...its nice when it turns out to be something cheap /forums/images/icons/smile.gif
  9. dyeager535
    26,980
    You might try tightening the bolts up a hair more, you'd be surpised what a couple more ft-lbs of torque will do.
    (had the same problem, the bolts were just a hair loose)
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    yeah, I thought about that but they were tight.
