Coolant Leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by daleearnhardt01, Jan 11, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Got a water leak that I cant quite figure out where its coming from. Its really slow and on the front of the motor. I runs down a wire loom for the starter, then drips to the axle vent tube, then drips off the axle. I put some BarsLeak in it and it stopped it for a while but now its back. Pressure tested it and it didnt leak so Im at a loss. One of the other mechanics at work said it could be intake or a freeze plug. Another person said possibly the weep hole on the water pump. I hope its just the water pump. Any other ideas?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If its the weep hole, yeah, thats any easy change...barely tough your finger under the water pump where the weep hole is and see if there is any fluid coming from the hole.
  3. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Check up on the intake, around the thermostat housing, sometimes you will get a leak there that will run down the front of the engine. /forums/images/graemlins/smile.gif
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'm goin' with the water pump on this one... Use a mirror and look at the weephole on the bottom of the pump. Also check the hose(s).
    John
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    yeah I talked to Chris the other day and told him to check that weephole...should be the problem
    Later
  6. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    You can buy coolant die and add it in to try and help locate the leak.
    Bill
  7. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    any update?
  8. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah I got an update /forums/images/graemlins/smile.gif I needed to get my steering column tightened (no way Im gonnna do it) so I let one of my co workers at the shop do it this week. While he had it in there we put it in the air and he looked and looked and couldnt find anything really. I guess the BarsLeak stopped the leak. Water pump looks good and the pulley has no play so thats all I was really concerned about - waterpump or not. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I will say this, the only problem with Barsleak is that it can plug you heater core. Thus nescessitating replacement /forums/images/graemlins/tongue.gif I hope it works out for you, however. /forums/images/graemlins/thumb.gif
    John
  10. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Hmmmm never thought of that John. Oh well theyve all used it for years at the shop so its probably ok.
