Coolant level question
Discussion in '1982-Present GM Diesel' started by Can Can, Feb 28, 2004.
  1. Can Can
    15,555
    145
    Cochrane, Alberta, Canada
    How low does the coolant sit in YOUR rad when the engine is cold? Is it full to the filler neck or down a few inches?
    I have a post going in the Garage detaling a problem I'm having with my coolant level if anyone needs more background info...
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Mine is at the neck. Had the "low coolant" light come on once. When I checked it (cool but engine running) was down maybe 3-4 inches, res had maybe an inch or two.
    When I went to fill it (engine off about 12 hours later) it was full???? /forums/images/graemlins/dunno.gif I know I have a teeny tiny leak at the thermostat housing and another on the heater hose (stupid mid-hose splice), but it stays pretty constant level.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Usually it should be a little low when cold, to leave room for expansion when hot.
    The newer trucks have the expansion tank or recovery tank and with those you will have the water up to the neck and when it expands it will go in the tank and then when it cools down it retrieves it from the tank.
    /forums/images/graemlins/thumb.gif
