coolant seeping around distributor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mrpoorboy, Feb 21, 2006.
  1. mrpoorboy
    mrpoorboy Registered Member
    Feb 21, 2005
    84
    hillsboro, oregon
    so what does coolant seeping out around the distributor area mean? nothing dripping on the ground, no white smoke when i drive and the oil is not cloudy. 350, 4 brl, 86 blazer. any help would be appreciated. thanks
  2. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    Is the coolant actually coming from the distributor hole. I highly doubt this. I have a heater line in the back of my intake. Also check the seal of the intake at the heads.
  3. mrpoorboy
    Feb 21, 2005
    84
    hillsboro, oregon
    from what i can tell, coolant is not coming from the distributor hole itself. really damp on the top left rear of the block. most likely seal is bad on the rear of the intake manifold. how difficult is it to replace the intake manifold gasket for a rookie?
  4. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    ive never replaced that gasket but only tip i can give is when your there make sure you get rid of the old one completely
